1 - 3 of 3 Posts
Is there any step by step guide on how to make a bb mod that goes right after the tb then a air filter and what plugs an hoses go where.. Just bought a celica in pieces REALLY need help S:
THANKS!!
Sticky at the top of the forum will help you find a lot of the mod threads :):
http://newcelica.org/forums/showthread.php?t=214875
BB Mod v1:
http://www.newcelica.org/forums/showthread.php?t=112681
BB Mod v2:
http://www.newcelica.org/forums/showthread.php?t=205453
GT or GT-S?
I can answer from a GT perspective...
If you're wanting to figure out the extra vacuum lines just look at any other short ram or cold air and you would need to add the right ports. Someone correct me if I'm wrong but I believe you on need one port for a short section of hose going from a VSV to the intake. Otherwise any other vacuum lines are either going to VSV's or eliminated when installing an intake.
Here's the install instructions for an AEM cold air, it might help you figure it out.
http://www.aemintakes.com/instructions/AEM-21-564_inst.pdf
1 - 3 of 3 Posts
