The wire that sets the alarm off is actually a simple splice into the horn wire inside of the steering column!!! This will be VERY easy for you to unsplice from the car's wiring harness and use that wire to the "+" side of your siren and then the "-" side of the siren should go to gnd.
You'll need to take all of the plastic off around your steering column......there are 3 screws that hold these plastic pieces on.
Once the plastic is off, look at Step #11 and Figure C6 in the following installation manual. You will see the Wire Side View of the plug that that the wire is spliced into.......there is an ARROW point to the EXACT wire where the splice should be:
