Can it work? I read somewhere that it was only for manual. Any ways to make it work for the auto gts.
I think some versions of the kit include a tuned ECU or some sort of "black box" that is wired to the ECU -- that wouldn't work with an auto in the former case, and may or may not in the latter case.Why do you think it wouldnt is my question?
I don't see why not. A WOT switch should work fine. It'll just take a little experimetnation to set it up properly.ok after reading that it seems you could possibly bypass using the blitz ecu and use a piggyback then wire in relay to something else (an out on the new piggyback) to somehow activate at the correct time (whatever the blitz ecu wants it at). or use a WOT switch?
