1 - 20 of 2668 Posts
7.4 only reached 33 pages and started lagging again, so here is a new one again :faint:
DA General of the ARMY
OK SO just came back from shop on my lunch. my clutch is fine. i kinda just bog in second. i dont like that. says check all my hoses for a vacuum leak.
Trust me, I'm Asian.
Get your car rolling at like 2.5krpm in 4th and then floor it. I think that's how you test for slipping clutch.
I thought the serpentine belt only drives the accessory stuff like alternator. Why would that affect how the car performs?
Alternator provides the electricity for your ignition system, ecu, etc. Kinda important.:chuckles:
I mean if the car is running and has electricity. Unless the belt is slipping so much that it's dropping the voltage at the plugs then I guess that'd cause the car to be slower :shrugs:
that's what the tC is.
Nope the tC is a Camry coupe. tC has the Camry engine. Corolla has the 1zz.
Ultraviolent
I mean if the car is running and has electricity. Unless the belt is slipping so much that it's dropping the voltage at the plugs then I guess that'd cause the car to be slower :shrugs:.
It's not like a light bulb that remains on dimly as power drops.:laugh:
If it's below a certain voltage, it just won't turn on/stay on.
The tC weighs more than 3000lbs right? And the Corolla was around 2600lbs.
So we agree that a slipping belt is not the problem with Oscar's car :shrugs:
