1 - 19 of 19 Posts
I have some light blue smoke coming out every time i go into boost. I don
Normally blue smoke means your burning oil. On older cars i would of said one of the pistion rings have gone and is causing oil to be burnt with the air and fuel.
Get it checked out ASAP
Discussion Starter #4
i was thinking that, but it didnt do that before. I've had the kit on for about a month now.
check your oil quality and level - smellit and make sure its not contaminated with fuel.
How rich are you running now? Could be just unburned fuel in your exhaust gas and that should be ok if you're running very rich for safety.
What do you think, Boosted 2.0?
I just didn't mentioned that your car didn't smoke before and that it doesn't seem to come out of the exhaust...mhhh...
rich conditions tend to be grey smoke if this is blueish its probably oil. Could be rings - I would do a dry and wet compression test and a leakdown.
Is your PCV hose (the hose the goes from your valve cover to the intake piping) connected correctly. Ie. it's not connected to the outlet side piping and under pressure?
Discussion Starter #11 (Edited)
I have the turbo-performance kit so i have no idea how the hoses were supposed to go. This is what i have:
I have the turbo outlet to the wastegate's bottom inlet. I have the hose that used to be connected from the AEM CAI now connected to the TB/MAF/BOV pipe and i have the bov connected to the small nipple outlet in the intake. the T goes to a boost gauge and the emange pressure sensor.
That's all i have everything else is the same. Should i unhook that hose? or is that just for the SF kit. btw i ahve a GT-S
ok yell at me and tell me how to hook this uo the right way. thanks!
unhook it from the throttle body and cap it.
Discussion Starter #13
where can i get those little filters for the pipe? do i need one or should i just cap it?
Can you see the actual turbo from underneath the car? You could check for oil leaks from the turbo. Or perhaps the banjo bolts for the oil lines to the turbo.
Also, how many miles do you have on the engine. Could be some engine seals leaking.
All of these can be checked when you look from underneath the car.
filter goes on the side coming from the valve cover cap goes on the throttle body itself
Discussion Starter #17
thanks! that worked. smoke is gone!
could've i have caused any damage by drinving like that? I drove the car liek that for aobut 1 month.
If you kept the oil changed very regularly and the level topped up you are probably OK. The main dangers in pressurizing the crankcase are massive oil leaks and reduced power.
1 - 19 of 19 Posts
