You need to take your VIN to the dealer and they will match the sunroof with the VIN, that will be your correct P/N.
I sure hope it is not going to be that involved. They say it is simply removing 4 torx screws and then replacing the glass tightening down the same screws you took out.blugts said:How hard was it to remove the original sunroof to install the new one? Did you have to take out the headliner and panels?
Everything fit as well as the old resin one? Had any problems with the rails or motor or anything?Barabaika said:Yes, 4 screws. You need a torx screwdriver.
It's a direct replacement.DopeCelicaGT said:Everything fit as well as the old resin one? Had any problems with the rails or motor or anything?
