Is there a special tool to get down to the spark plugs to change them? I have 57000 miles and think they may need changed?
no, i know there is a socket for them, do you have to use an extension though? how do you keep them in the socket without falling back down in?
special socket...
There is a special socket for spark plugs. There is this rubber thing inside that holds onto the plug. It makes an airtight seal with the spark plug, so the vacuum inside of the socket hold the plug so you can bring it out. There is this other thing. Its like a thing stick with a magnet on the end. I used to use that before I got the correct socket... Go to your nearest Autozone, they'll hook you up.
