1 - 4 of 4 Posts
Hey guys, I'm ordering BC coilovers extreme drop. I wanna know what spring rate y'all are using and what kind of ride you get. I don't want a ride that's super stuff.
I will probably drop my car about 3"
im on 8k/10k if I could do it again id get something stiffer. Rides great coming from blown shocks so I cant say much
20kg/mm fronts and 25kg/mm rears. Anything less and you are a bitch.
But seriously it all depends on the spring itself. If you are getting BCs get the Swift springs in something like a 8k front 10k rear and you should be pretty good. The reason I say to get Swifts is because BC springs are not very good and a quality spring will allow you to go up in stiffness while maintaining a decent ride.
I run 700lb/in front and 650lb/in rear Hypercos and the car rides smoother than it did with 8k/10k BC springs.
Spanning Tree Storm
default
1 - 4 of 4 Posts
