1 - 2 of 2 Posts
Weird topic I know, but I wanted to check with you guys on this.
So I recently dropped my car on s-techs, it took about 2 weeks of DD for the springs to settle in nicely.
So all last week I was doing a rear GTS brake swap and had the rear of the car up on stands for 7 days (was waiting on new brake lines from the stealership)
So anyway once the car was finished and put down onto the ground, the rear is jacked up again to the first day I installed the springs?!?!
Its almost like the springs, since they had no weight on them, expanded back out. :confused:
Just checking with you guys to see if this is normal, or has happened to you before.:confused::confused:
Thanks
O_o
They may just have to settle back into place, also be sure to check and see if the springs have rotated out of their seat.
1 - 2 of 2 Posts
