I think you might have misunderstood what my question was. The plastiguage is being used so I don't put down another thousand on tools I will only ever use once or twice in my entire lifetime. If I had access to highly precise micrometers and bore gauges, I wouldn't need plastiguage. But it still works, I have it already, Toyota says to use it, and the only thing it can't fully do is test for roundness. I've gone ahead and ended up replacing everything in the rotating assembly, so everything except the rods are new, and all 4 came from MWR and have been verified round and straight.
I simply need to know if I need to torque the main bolts to spec without turning the extra 90° to test my clearances since the manual doesn't elaborate it very well. I know the bolts are Torque-to-Yield, and I don't want to ruin them because I stretched them while measuring clearances. I'm not out of my skill zone, I simply do not have shop level tools because I don't work in a shop and can't justify spending the money on them, and the Toyota instructions are half-baked.
There was NO way for me to determine the correctness of any of the parts involved until I had them all together. I purchased everything in standerd size because I have to start somewhere, so that includes all the bearings and the crank itself. I can also just reduce surface material along the races instead of shaving the bearings if I need to, which is much simpler. I know each main journal is cut differently too and I had asked about that earlier.
