1 - 1 of 1 Posts
*NOTE: The Front Turn Signal bulbs are incorrectly labeled as 1156.
They are actually 7507.
*NOTE: The 2004-2005 Celica Tsunami (Canadian) Edition have 9006 bulbs for their fog lights.
A/C panel Bulbs: Toyota P/N 90010-05126
you unscrew both screws that are on the black plastic piece (the two holes next to the white knob in the middle). you very gently pull out the circuit board, repeat...gently!...do not pull it out all the way, just enough to make it lean forward a little so you can untwist the bulb in the back. replace bulb, and then replace the screws onto to the black plastic piece.
Or replace w/LEDs
1 - 1 of 1 Posts
