I went to go remove two subframe bolts to install Cusco under chassis bar. One came out fine, the other (passenger side) bolt was turning but it was difficult. After tightening, loosening, tightening, loosening trick the bolt just started spinning in place. It didn't break, it's still in the car but I can't tighten it or loosen it, it just spins.
So I think that whatever the bolt screws into (not sure if it threads directly into the chassis or to a nut welded to the chassis) has become loose and is spinning.
Anyone know of any access point to the top of this bolt so I can repair it. Google hasn't helped me much.
I was really worried at first but I'm not too worried about now. I think I'm kinda lucky, I'd rather have this than a broken bolt to drill and tap on the frame and that bolt was maybe 2-3 mm backed out so the subframe is still supported.
