1 - 11 of 11 Posts
I'm looking to modify my Celica's handling ability. The car is already lowered on Tein springs and I want to improve the handling before doing serious engine modifications. What suggestions do you knowledgable Celi owners have?
Replace every suspension bushing with poly and change the sway bars.
Ah funny that you mention bushings. My car had insane squeaking issues because of the rear bushings! What about fuel pumps? I've been looking for one to put with injectors I got for the car, but not until I resolve a lean issue with the car.
Bushings and sways I highly agree, celicas are old now and it's time to replace those old rubber bushings
If you can find or make one I'd also highly recommend the SpeedFried Rear roll adjuster kit, basically a rear subframe lowering kit to lower the rear roll center of the celica. Well worth the money
Discussion Starter #7
Any links for this or just plain searching? As I mentioned before, solving the lean issue is priority #1
Replace the intake manifold gaskets. P0171 - System too lean Bank 1, right?
Discussion Starter #11
Yes, this code had disappeared when I replaced the EGR and cleaned the MAF, but reappeared now with a strange chirping noise similar to a cricket.
1 - 11 of 11 Posts
