1 - 4 of 4 Posts
after i washed my car, i opened my sunroof, and it was really dirty on the sides where the rails go. so i cleaned it all off, knowing that there was some type of grease there. so i put some wd-40 on both sides (it helped stop the squeeking). i know wd40 isn't nearly as thick as the stuff i cleaned off. what should i use instead? i don't think the wd prevents rust either, so i need something that helps protect it. any suggestions?
-aaron
Is there any noticable difference in the spray or tube? Does one work better than the other? Stay on longer? Reason I ask is when I put in my short shifter all I found was the spray and wanted the tube, which I finally found.
1 - 4 of 4 Posts
