1 - 13 of 13 Posts
just randomly stopped working one day?
Pop the switch out of the headliner, Check continuity between the pins when buttons are pressed.
Ill try and get you the exact pin-out.
Lurking06 Celica07 Join08
this might sound stupid, but its common. Make sure you check it with the ign on.. he could have put the key in but didn't realize he didnt switch the key on for power to get to it.... did you check it yourself to verify it doesnt work?
Yup i checked it. Turned the ignition on/ACC everything. The thing doesn't move. I'm gonna see if the tracking on the sunroof is good. Maybe something's blocking it? I pulled out the switch from the headliner... But don't know which pin to look for. Hmm... I'll play w/ it more tomorrow.
i was reading this and i was like joey doesnt know this shiit wtf is going on here then saw it was alex with a picture of joey :chuckles:
As$hole!!!! I know what he's talking about fool. <----Bullshiit! :gap:
How do u identify the pins to check for them, I took the panel with switch and lights out but don’t know what pins are, help!!!!
1 - 13 of 13 Posts
