Suspension components.....
1550 Views 8 Replies 7 Participants Last post by  mkyEND
Ok guys......finly decided to go with lowering the car....
2000 Gt, i need to know ALL the components i need to order for a 1.4" and 2" drop..
Im planning to order my parts at the end of the month..
Thanx in advance.....
1 - 9 of 9 Posts
So you're lowering the front 1.4" and the rear 2" or vice versa?
WHY?
bc coils you can adjust to where you want, they come with all the top mounts so you won't need a spring compressor.
it depends on your budget
if you have a ground laying around, then hell fucking yeah get bc coilovers
but if you have a smaller budget, for that drop, get tanabes df210 and kyb agx struts, i think its around 600 dollars ish?
overall, you'll only need new struts, and the lowering springs (or the coilovers)
if you want to spend more money, you could replace all the end links, and the sway bar linkages, but that's not really needed, but it could be done as your car probably still has the original ones, and will need new ones.
I'm either lowering 1.4 OR 2 inches all around. Its the components list i need!
Camber kit ect... What hardware do i need for either 1.4 or 2".
Your rear camber should fall within realms of the stock adjustment, if you get BC's or similar then the front top plates are camber plates so you're set there too. I'm dropped about 2 inches and run about .5 and 1.3 camber front/rear. I'm not even close to maxing out the rear adjustments, I could still go more positive if I wanted.
If you're over 100K miles I'd suggest replacing the control arm bushings as well, they're probably crap.
yeah you usually dont need a camber kit until you're dropped 2+ inches
and even then, you dont really "need" a camber kit, as unless you're pushing -3+ camber, it wont make a huge difference in your tire wear.
before i changed my wheel setup, i was able to get probably around 80% of the "optimal tire wear" when i was running -4 camber, as long as you zero the toe, camber wont make a huge diff.
If over 100k+ miles and have all original parts, inspect and replace as many small suspension parts as you can. Parts such as sway bar bushings, control arm bushings, ball joints, tie rod ends (inner and outer), and definitely end links. You have to disconnect end links, so you might as well put new ones in.
^ this
Unless you have relatively low miles on your car, chances are some of your other suspension components will need replacing after you lower it. The more you lower your car, the more stress you put on all the other parts of your suspension.
Most of what he listed are relatively cheap to replace. If you decide to get BC coils, they do come with new end links. I'm not sure what other brand of coils come with them as well.
While its recommended that you give the entire suspension a look-over when you lower your car, technically the only thing you NEED is either new springs + struts or a complete coilover system. When I first dropped my Celica on BCs, I maxxed it out and didn't replace any other parts. I didn't even have a rear camber kit. I was sitting pretty low, but luckily none of my other suspension parts ever went bad.
To put it into context of the age of the car, however, my Celica had maybe 70 or 75K on it when I first lowered it in 2012, which is relatively low for a model year 2000 car. In contrast, I owned a 2005 RSX-S which I lowered at 120K. About a month after lowering it I had ripped the CV boots and my bushings were completely shot. Your mileage may vary and you may or may not have parts failing on you after you lower your car, but to be on the safe side you should at least consider replacing the other parts of your suspension as well.
And for the love of god, even if you don't decide to replace any other parts, at least get a proper alignment soon after you lower it. That alone will make a world of difference.
1 - 9 of 9 Posts
