i will soon be installing hotchkis sway bars and had a question. right now my suspension mods are:
Kyb Agx Shocks
Hotchkis springs(will be swapped with GC coils soon)
Cusco lower tiearm bar
stock endlinks
I know that Tien/Hotchkis causes endlink problems but is that tien/hotchkis setup specific? or is it any kind of set up. I even read that hypermotive endlinks might snap due to the stiffness.
Also i'm looking to set up the suspension towards oversteer. for the sways what should i set them at and why? i've been in cars with tien/hotchkis set up and it felt like i was riding a go kart. i wasn't sure if it was the coils or the sways doing the work. if some one can explain in detail of the sway bars that would be greatly appriciated.
Originally posted by MicaCeli
DO NOT put GC coils on your car. You will hate the ride.
hehe, my friend has gc coils with kyb agx and i actually like the ride :) i guess each person has different taste
Zettai Unmei Mokushiroku
jdm-style[/i] [B]I know that Tien/Hotchkis causes endlink problems but is that tien/hotchkis setup specific? or is it any kind of set up. I even read that hypermotive endlinks might snap due to the stiffness. [/B][/QUOTE]Stock and Hypermotive should work fine with your current setup. The front Hotchkis springs only lower 1.4" said:
I guess the AGXs are stiff enough to control them, just like Konis. I know with stock struts, you'd be bouncing all over the place because the GC's spring rates are way to high for the stock struts to control.
