Who has swapped bolt
1 - 7 of 7 Posts
115k miles and still not swapped out... although i rarely ever hit lift so they work fine.
soon to be swapped....wheres the category for that :(
Swapped kind of... Valve cover still off due to broken bolt. Extractor kit failed and its a pain in the a$$ to get it out. been broken for 2 weeks now. If you do change the bolts, have money standing by if a bolt is broken or have another car and some time to do it yourself. the bolts cost what? about 68cents? x2 = 1.36 for bolts.... Extractor kit for broken bolts is about 4-40bucks depending on what you buy, 300-600 for Toyota to fix it and remove the broken bolt, Stripping the threads on the head when trying to remove it with the extractor.... Priceless. :angry:
All I have to say is... Good Luck buddy. Use the search and search for Remove lift bolt.... You will notice though that you get more search results looking up broken lift bolt.
1 - 7 of 7 Posts
