I'm going to get a pair of hotchkis sway bars off of bottle in a little while, and my question is: should I get the hotchkis street sways, or the comp sways? and also what the difference (drivabilitiy) between the two?
So they're not adjustable, then?Originally posted by abilko
About the endlinks - Hotchkis still makes the endlinks. I ordered a set (front and rear) for $185 directly from Hotchkis about a month ago.
But the front links are significatly shorter than stock. So if your running stock struts they probably won't work.
Because that's you and me. You should expain the differences one more time if you don't mind. If this person is asking than the street sways will be more than good enough.Blue Bomber said:Hmm, why do you suggest the Streets over the Comps? I had no problem with my sway setup (equivalent to the Comps).
