1 - 4 of 4 Posts
Im trying to find out what happens when there is fluid in the brake lines.
What is happening...
When Im making a full stop, the car will jerk slightly right before I stop. It only does this when I brake slowly, not at a hard stop. It will only do it once, then I stop.
I don't have any problems on the freeway when braking. I had my rotors checked and they are not warped.
I think it might be air, but could I have sticking calipers? I have no other brake problems.
sounds like a sticky caliper piston/caliper guide to me.
Stop the car on a slight incline, pump the brakes a few times, put it in neutral and see if the car will roll at all.
No movement = sticky brakes.
It could also be a worn tie rod end or ball joint, possibly a bum steering rack, possibly a loose or worn strut mount/bushing.
1 - 4 of 4 Posts
