i finally got the system to work but now the system remote wire isnt geeting a good connection. I then cut the metal thing off and tried to connect the directly to each other but that didnt work so i soldered the metal peice back on to the headunit's SRM (system remote wire) and it now gives me a weak sub playback. What should i do? my SRM always came undone if i turned too hard or something like that. Please help
Can I get that said again in english please?
you guys suck with audio crap if you dont understand.. ok firestorm like i told you on AIM re run your remote wire if youve already checked it in back of the headunit and amp. its most likely cut somewhere.. also what gauge wire you using
Actually I'm very good with audio and electronics, but it helps when you explain your problem in complete clear sentences with some terminology other than "the metal thing".
Also the remote wire gauge doesn't matter and shouldn't be larger than a 20-18
But ok, you go ahead take care of his problem :thumbup:
