1 - 2 of 2 Posts
the other day i went to take out my driver's side headlight because moisture is getting in and i want to find and seal up the whole, but after taking out the bolt from the top and the bottom one. i could not get it out, i was able to wiggle it but it was like there was a bolt still holding it. :wtf:
So does anyone know were this bolt is because i couldn't find it.
there is another bolt on the bottom. you have to bend back a little bit of the fender lining and remove the 10mm bolt holding the bumper to the fender. its at the corner of the bumper where the fender and bumper meet. then you can pull the bumper back a little and get to the other bolt that will be facing you. its in the middle of the bottom of the light. just be careful if your going to pull the bumper back to get to the third bolt. you can also remove the bumper completly but this is much faster. hope that helps.
1 - 2 of 2 Posts
