1 - 20 of 594 Posts
Website: Jmautosports.com
Email: [email protected]
Contact: 516-287-8522
2000-2005 Toyota Celica Medallion Touring Exhaust
Item # T70036
MSRP: $690.00
Our Price: $599.00
You Save: $91.00 (13%)
Free Shipping
The elegant, well defined appearance of MEDALION TOURING is mature, and matches the artistry of a tastefully built, highly tuned machine. Using the all new 'continuous strand' ADVANTEX packing material technology, MEDALION TOURING achieves extremely high levels of exhaust system efficiency, while maintaining a street drivable, extremely low frequency and deep tone that is well under 93db for discreet sports Advantex Exhaust Technology All Tanabe Medallion Touring exhaust use advantex performance technology. Advantex is a highly advanced muffler packing material that greatly excels over other packing material types such as loose packed fiberglass mats and composite cube types. Advantex internal packing material allows the muffler to reduce sound more with less material, while still maintain extremely high flow characteristics. Straightest From, Mandrel Bent Minimizing is a goal of each custom-built Tanabe exhaust system. The truest form is realized to minimize restrictions and maximize usable power gains. Where necessary, the piping is mandrel bent for improved exhaust flow characteristics. O2 Sensor Placement While the catalytic converters are removed to maximize the flow, we retain all factory 02 sensor mounting locations. ? High Grade SUS304 Construction Tanabe was one of the first Japanese aftermarket companies to create full SUS304 stainless steel exhaust system many years ago. The highest grade SUS304 stainless is used on all systems for maximum durability, as well as keeping it lightweight. Weight Reduction Because every bit of weight savings is beneficial, exhaust hangars have hollow construction to reduce weight. Further weight reduction is achieved and utilized through the use of pressed SUS304 exhaust flanges on portions of the system.
Pipe Diameter - 60mm
Tip Diameter - 100mm
000-2005 Toyota Celica Tanabe Medallion Concept G Exhaust
Item # T80036
MSRP: $690.00
Our Price: $599.00
Free Shipping
CONCEPT G is an all new motorsports-developed exhaust system that features high power benefits, while maintaining responsible sound levels. Using the all new 'continuous strand' ADVANTEX packing material technology, CONCEPT G achieves extremely high levels of exhaust system efficiency, while maintaining a street drivable, extremely clean sound output that is under 93db. The full SUS304 stainless CONCEPT G is designed for optimal pipe routing as well as ground clearance. It's sporty appearance and angle-cut tip is ideal for the sports car & sport compact driver.
Pipe Diameter - 60mm Tip
Diameter - 100mm
Discussion Starter #17
TAKE ADVANTAGE OF BLACK FRIDAY. All purchases automatically receive a free $10 coupon for there next purchase!! All normal discounts still apply!
1 - 20 of 594 Posts
