TSBs (updated links)
TSB: Loose Door Handle
TSB: Tire Inflation Pressure and Wheel Torque
TSB: Various Rattle Noise Solutions
TSB: Various Rattle Noise Solutions Warranty Info
TSB: Tighter Shifter Springs
TSB: Valve Adjustment
TSB: Valve Adjustment Steps
TSB: Daylight Running Lamps Removal
TSB: Sunshade Removal Instructions
TSB: Brakes Making Clicking Noise
TSB: Check Engine Light
TSB: Seat Belt Tongue Plate Stopper
TSB: Wind Noise Reduction Steps
TSB: Sunroof Separation Problem
TSB: Speedo and Tach Fluctuations
TSB: Bodyside Weatherstip
TSB: Problems with Auto GTS Tranny
TSB: Wheel Balance Adjustment
TSB: Shoulder Belt Appearance Fix
TSB: 6spd Selecting Gear Problem
TSB: Moonroof Creaking Noise
TSB: Dealer Codes for Programming Factory Alarm
TSB: Valve Cover Oil Baffle Damage Prevention
TSB: Driveshaft Nut Chisel Tool
TSB: Belt Tensioner (NEW CELICA SPECIFIC TSB)
High quality Pics of Valve Clearances
2000 Celica Manual Page EM9 Valve Clearance for 1zz-fe
2000 Celica Manual Page EM10 Valve Clearance for 2zz-ge
2000 Celica Manual Page EM11 Valve Shim selection chart for 2zz-ge
