Yesterday I was installing my HID kit but can't figure out where the 2 bananna plugs go I know the other 2 wires plug into the bulb but where do the other ones go?
The white harness that plugged into your stock bulb right? I knew it went into a harness but it didnt look like it would fit any of them.
They arn't banana plugs their flat spades. The red goes into the red wire in the stock wire connector and the black goes to the white wire ( i think thats the color)
that's because your wire was cut. splice it or better yet buy 2 metal clip that goes into that white plug.
Techone sucks :thumbdown:. If you are under the so-called warranty make sure to ask for a new ballast and don't send your ballast back. Why? coz there's nothing wrong with it. I had mine died out, got a newer one and was ask to send back. I forgot to send it back then my new ballast died. I just ended up using the old ballast that died out first. I don't know why it work but it did.
