1 - 2 of 2 Posts
I'm about to order my new Tein - S techs, and came across the Tein h-techs. They are made with a different material and have a 0.8" drop instead of the S' 1.4" drop. What do you guys know about these?
Thanks,
Christopher
Tein HTech Lowering Springs
TEIN High Tech springs are made from a new material called Vanadium which is much lighter then other spring and increases flexibility. TEIN H-Tech springs are designed for the most comfortable ride while providing the most performance. If you are tired of an uncomfortable lowering spring, the TEIN H-Tech is for you!
All spring are designed specifically to fit each car for maximum performance.
About a 1 inch drop for a more attractive appearance.
Comfortable ride quality is still maintained by using the OEM bump rubber and noise protection sheet.(available for most model)
1 - 2 of 2 Posts
