I did some research on the tein s tech and h tech i know the h techs are the best ones to go with but are the s techs really that bad or are they just not as good as the h techs?
Zettai Unmei Mokushiroku
The H techs lower the car less than an inch, the smallest drop out there for the Celica. I'd say the S-Techs (1.4") would be better since they lower the center of gravity more than the H-Techs. There's nothing wrong with using either, unless you're only using them for appearance. Then you'd be very disappointed with the H-Techs.
Originally posted by SatansLilCelica
I would recommend some great springs... But, Blue would get mad (jus because he doesnt run the best).
Oh, I could recommend the same springs too, but seeing as how I have so little info on them, and nobody seems willing to share what they know, I cannot in good conscience recommend them, especially since they cost more for what could be the same performance. :)
Originally posted by Red01GTS
You two should get a room.
We could... But, all the Eibach banners on the walls of the room would intimidate him......... All lil Blue would be able to ask for would be the spring rates (since he is the authority on they would perform).
