1 - 20 of 53 Posts
This thread is a central repository for engine swap questions and will be a sticky. I will link any relevant past threads to this one in an organized fashion to make looking for information on the swap you are interested in easier. If anyone knows of information on a swap (sucessful or not) or a thread that would be worth adding, please reply to this thread with a link to it. Thanks!
1ZZ -> 2ZZ Swap - AKA GTS into GT chassis
Satus - Completed by numerous people
Cost - Varies from $3000 - $5000
http://www.newcelica.org/forums/showthread.php?t=226223
http://www.newcelica.org/forums/showthread.php?t=329500
http://www.newcelica.org/forums/showthread.php?t=286938&highlight=2ZZ+swap
3S-GTE swap
Status - Completed by 2 shops
Cost - $10,000 and $50,000 respectively
http://www.newcelica.org/forums/showthread.php?t=187790
http://www.newcelica.org/forums/showthread.php?t=249537&highlight=K20+swap
K20 & other Honda Swap
Status - Not Completed or Attempted
http://www.newcelica.org/forums/showthread.php?t=289962&highlight=K20+swap
http://www.newcelica.org/forums/showthread.php?t=230025&highlight=K20+swap
http://www.newcelica.org/forums/showthread.php?t=105881&highlight=K20+swap
http://www.newcelica.org/forums/showthread.php?t=215540&highlight=K20+swap
2AZ / Scion tC swap
http://www.newcelica.org/forums/showthread.php?t=291419
http://www.newcelica.org/forums/showthread.php?t=212859&highlight=K20+swap
1JZ-GTE RWD swap
Status - One attempt
Cost - unknown
http://www.newcelica.org/forums/showthread.php?t=232418&highlight=santa's+workshop
2JZ-GTE RWD swap
Status - One attempt - completed (almost)
Cost - Over $32,000 and counting in parts and materials - owner has done all labor himself.
http://www.newcelica.org/forums/showthread.php?t=317092
Other Swaps
http://www.newcelica.org/forums/showthread.php?t=51853&highlight=K20+swap
RWD Conversion
Status - One attempt - see 2JZ-GTE swap
http://www.newcelica.org/forums/showthread.php?t=239323&highlight=2ZZ+swap
Tacoma 4cyl RWD swap:
http://www.newcelica.org/forums/showthread.php?t=273176&highlight=Paradise+racing
Discussion Starter #3 (Edited)
wat about the celica that's from paradise racing with the Tacoma engine did u put that one in?
Yup - thats the one listed under RWD conversion I think
Discussion Starter #5
I guess there is one other 3S-GTE Celica although it's technically not a swap but the Wedsport JGTC car. It still uses a ZZT-231 chassis even though I would assume heavily modified but if someone has the crazy dream of a RWD 3S-GTE swap in their Celica they could use that as a model.
How about a 2zz in a 1992 civic? :AF: I had a Corolla Xrs and it got totalled.. I miss lift so I think it would be pretty cool to start this project..
Because Rotary
Hey some quick question. Do I really have to get the pass. side engine mount? :)
I have a 1zz alt, but I don't have power windows, locks, or Cruise Control, so can I just use what I have right now.
I have the engine, manifolds, flywheel, and throttle body.
I have a 1zz CAI. Can I use it as long as I get a new coupler because of the TB differences?
I'll need a new throttle cable even though I don't have cruise control because of the TB differences?
I still need the Midpipe flange and an ECU and Knock sensor.
I think I have everything after that, if I go by what the thread says I need. Do you guys have any other input? I'm trying to get everything together by spring break so I don't have to miss school. If I miss 3 days they take away my financial aid lol.
Hi guys, Im looking into swaping a 2zz and 6speed trans from a 2006 xrs and Im wondering if taking the 2zz from a corolla will bring me alot of trouble or if its about the same? I know its been discussed recently but I couldnt find it back. Also how much is the wiring cost since the engine im buying dont come with it?
Thank you!
David
Discussion Starter #13
** my car needs to be added to this list as completed RWD conversion 2jzgte non drag car
Added. What should I put for cost?
i would have to add it up man i think the last time i looked... and it was a few months ago i was past $32,000 US
Discussion Starter #15
Are you including your own labor in that, or was that just parts?
1 - 20 of 53 Posts
