You all know this noise. What have you done to eliminate it?
what noise? i have a noise like "pop" sound when i hit high speeds, and it's coming from the moonroof somewhere. is that what you're talking about. i have no leaks or anything, but it does get me scared when i'm gassing it to 90mph.
That might be the noted bad weld....there was a whole thread on that... I forget the exact resolution... I seem to recall adding rubber underneath or filling the hollow crossmember with insulfoam.
slidr said:
Open it and wipe the edges with a wet rag.
Yes, clean the rubber egdes and where the rubber meets the roof line.. actually, I threw some ArmorAll on it....that solved one of my noises :)
Then there's the possibility of loose pop rivet/screws on the moonroof.
There is another noise that almost sounds like moonroof... but actually comes from the map/dome light... rubber underneath is the fix for that.. & is in the TSB...
I still have another small one in the dome/map area... but I'll nail that someday when I feel like attacking it....
