1 - 9 of 9 Posts
I had no choice but to crash snowbank left across an off-ramp by a plow last night, after the latest northeast mini-blizzard. Th rest of the ride home I thought I might be hearing a 'SSKKKRRTT-SSKKKRRT" sound every now and then. Weeeell, leaving for work this am I was hearing it pretty much continuously. Go about a 1/4 mile, pull over, peek underneath, and I'm dragging both undertrays on each side, all mangled and bent up backwards.
:wtf:
Back home we go, pull the Vanilla Popsicle part way into the garage, and try to find my stash of extra pop clips. Could not find the baggy. Pull a couple off the door sill, which required chiseling the ice off, only to find that they are a bigger diameter than the ones used under the car....finally find another kind floating around in the toolbox botton, manage to pop them in, and woo-hoo, all the Stripper's droopy drawers are tacked back up.
Has anyone found a better , just as easily removable fastener than those things?
Try the specialty hardware section of Lowes or Home D. (usually a rack of thin drawers) bring a sample with you so you can match up diameter and length in a different style. Auto parts stores that cater to body shops have a large selection as well.
PS: I made up a modified pair of pliers to remove those stubborn ones used under the engine. It would have been nice if they had designed in a trap door type arrangement so you didn't have to pull the whole pan down every time you change the oil. No matter how careful I try to be, I manage to break a couple of those fasteners every time.
I haven't found an easier to remove option, but I have tapped threads in many of th holes (on the oil change side) and I use short bolts to hold the tray up. I think I used all my spare M8x1.25mm bolts, but a 5/16" bolt will work too.
I have never had one fall off. Soon, all of them will be bolted on.
Scott
Now Scott that is not legal. You must return to using plastic clips... :)
Rick is correct. Since I am confident a solid cone hit will not rip my car apart, it enables me to drive faster than the competition, it's a mental thing.
At least, that's how I would form the basis of my protest...
Scott
Lowe's sells 1/4 size rivet srews at 73 cents for 2. The head is smaller. It may not break as easy as OEM. I think you can find some strong pins similar to woman's hair pin working as easier as rivet. Try to see how it work.
This is follow up to my last post. I used it. The hair pin works great. U can buy thick one for 88 cents for 18 pins at drug store. It is easy and durable.
any chance you could show us a picture of the hairpins you are using?
Any pin as long as it can hold the plastic board tight should be good. I now use 2 thin pins for one hole. Only need one if thick pin is used. Go to woman's cosmetic store such as ULTA, I even find pin curl clips with spring for 64 cts (12 clips). There are many choice. Any pin or clip small and close to 1/4 in should do the job as long as it hold the board tight. Once u are underneath the car, you don't like to screw those rivets. However, keep a few good rivets and replace the bad one with pin until u feel comfortable.
1 - 9 of 9 Posts
