I have been looking for practical and affordable alternatives to upgrade my celica rather than buy full on aftermarket stuff. Perfect example would be the brakes.
I have an idea of adapting frs/brz brakes. i know that the rotor mounting dimensions are the same (center hole, lug pattern)
Thoughts on this?
the frs brakes have 2 pot fronts and a bigger single piston in the back. making an adapter plate is easy.
will i need to change the master cylinder?
Just wanna make sure im not outside my mind on this.
I was looking into an STi Brembo swap at one point since STis are pretty common in Washington but I never pulled the trigger on it. Really the hardest part is finding rotors to work with the setup but you can get custom ones made pretty easily/cheaply. Adam's Rotors would probably make you custom rotors as long as you know all the measurements.
Discussion Starter #4
that was in the back of my mind too. I would hate to buy anything and find out it wont work without fabrication. The whole reason i want to do something like this is so i can buy factory replacement parts when needed.
