Hi all,
My brother has a 2000 Celica GTS (2ZZ), and it has had a noticeable oil leak ever since he bought it. I have a 94 MR2 that I swapped out the 5SFE for a 3MZ V6, so figured I could help with his leak. I spent some time on google and found some posts on this site which were very helpful in trying to determine where the leak might be:
http://www.newcelica.org/forums/showthread.php?t=321080
http://www.newcelica.org/forums/showthread.php?t=343745
It seemed the most likely culprits were the timing chain tensioner o-ring and the valve cover gasket, so I replace those along with the crank pulley seal just to be safe. Put it all back together but it is still leaking the same. I did the talcum powder trick and it looks like it is coming from that little nook just above the timing chain tensioner, not far off from how it shows in that second link. I wanted to be lazy and just try to put some RTV over where I think the leak is and hope that keeps it in, but not sure that would be successful. So figure bite the bullet and change the whole timing chain cover gasket. But, I really don't want to pull the whole engine out to do so and also there isn't a lot of room between the engine front and the sidewall.
Anyone have any tips for taking off the timing chain cover to replace the gasket? I have a copy of the service manual which lays out the steps, but often there are helpful hints forum folks learn that don't make it into the service manual. For example jack up the engine to get to the main drive belt tensioner bolt, I had to loosen it to get the timing chain tensioner out.
Appreciate any advice, I'm kind of worried because there seems only like an inch of clearance between the front of the engine and the sidewall.
Thanks,
Rdubs
Thanks,
Rdubs
