41 - 49 of 49 Posts
I am looking to possibly replace the water pump. Toyota wants $300 for OEM. I was thinking Aisin but I cant find a part number for the 2zz only the 1zz
There is a second pump listed on that website. The engine is the same for both the manual and auto transmissions.
Gonna take the cover off again this weekend. Clean it up real good and see if I can notice anything.Try a little gasket maker and see a what happens. I will post some pictures.
So turned out it was a cracked timing cover. It was quite a significant one but I took it to a welder and they did their best welding it. It may hold or not. He was not able to weld the crack in the grooves but got the other side of it. I put some sealant before I put the gasket down to fill in the crack there.
I will fill the system tomorrow and find out.
Just an update:
I ordered a used timing cover from the boneyard. Cleaned it up and installed it. No leaks. The only struggle I had was putting the valve cover on. For some reason, it felt like it was warped (but it wasnt) as it was teeter tottering. I got it on flush once I tightened things down, couldn't see the snag. No oil leaks, or coolant leaks. Glad to put this project to bed.
The other issue I had was the dummy nut on the belt tensioner was rounding off, ended up getting a welder to weld an aluminum block so i could use a pry bar against it.
Last thing to figure out is the passenger engine mount, two blind nuts looked like it kinda came off its weld a little so I cant thread the bolt. I can see the nut but bolt is just spinning and the other one may be cross threaded. It may be because of my friend used an impact when installing ?. But I'll trying to figure that one out later without having to poke holes.
41 - 49 of 49 Posts
