1 - 20 of 133 Posts
so the tire shop doesnt do tire stretching. so im attempting to do it myself, but i cant get the bead to set to save my life. i even had 3 people pushing on it with me. any ideas?
EDIT: http://tyrestretch.com
If you choose to stretch your tires, you are inherently responsible for any possible damages. Stretching tires is at your own risk and may void any warranties associated to the tires.
Starting fluid and a ratchet strap. Strap the center down, spray ether around the bead, light that shit on fire, should pop the bead on. Old school trick brought back from Japan
Sent from my XT907 using Tapatalk 2
I wouldn't recommend that. It isn't the safest thing to do. You can fuck it up and end up needing new tires.
What I would suggest is to start calling shops and asking them if they do it. I know discount tire does it.
What size tire are you trying to stretch on what size rim?
215/40/18 on a 18x9.5
and discount tire said they will not do ti
Keep calling till you find someone, probably going to have to offer a cash deal with no warranty and no receipt.
I never said my way was the best or safest but it does work
I have done this before, only on tractor tires and it worked fine. I won't try it on a car tire.....
I don't care
Use the loud thing that squeaks. That's what its for.
That's not going to get a 7.5 in tire on a 9.5 in rim. The ratchet strap will get you close but the explosion us what will set the bead.
I don't care
Pfft! Torch it. We did it on a van last year
and a spider
Turbo 2zz
La tee fucking da
<iframe width="560" height="315" src="http://www.youtube.com/embed/N45KcCsBYmc" frameborder="0" allowfullscreen></iframe>
Discussion Starter #15
:gap: There's your problem~!
I got the size xBernie said for running flush.
La tee fucking da
See I know about the fire. Im just not sure that I want to do that. I dont want to hurt my tires or rim.
La tee fucking da
Just like that, la te fuvking boom
It wouldn't hurt it unless you spray too much. The guy in the video sprayed too much, at least I think so anyways.
Any tire shop should have a bead seater (Cheetah), since big truck tires are difficult to seat also.
Have you tried removing the valve core and pumping air in?
edit: Another trick I have seen, take a bicycle tube (small enough to seal off gap between tire/wheel) and put it between the bead of the tire and the wheel. Blow up the tube, air up tire, and it might seat. Can't guarantee it will work though.
1 - 20 of 133 Posts
