1 - 10 of 10 Posts
so i have 205/40/17Z toyo proxes ZF that are gonna die on me in about 2 months...i originally wanted to upgrade to the new TS style but considering i have an auto and some other good advice i decided against it and decided to stick to the same style. the tires perform really well, and i love the grip. they are not too loud after gettin' use to...
well the point is that i'm debating on whether or not i should stick with the same size or change...i'm thinking of going for a bigger profile to close the gap (i have hotchkis springs) and i wouldn't mind going a lil wider to cover more ground...
what is the best size? 215/45? can i go bigger? or no?
btw, i have RH M5...
215/45/17 is good. I have 225/45/17.
Go with the T1-S if you have the money and want the performance. It will put the FZ4 to shame.
tire size works like this :205/45/18
205 is the width of the tire in millimeters
45 is the height, its height is 45% of the width
18 is the rim size
i hope this helps
Discussion Starter · #9 ·
i think i'mma go with the either the 215 or 225..depending on price differential..but i'd prolly go with the latter..
if you go wider, it'll help protect your rims since the tires are a little wider.
nice sig, cowboy bebop is great :D
1 - 10 of 10 Posts
