No, it tears a hole in the shock tower if you tighten it as much as you're supposed to.Originally posted by Blue Bomber
The torque brace has a tendency to tear through the strut tower if the bolts ever comes loose.
Well, the problem is that one of the two bolts that are used to secure the brace to the strut tower doesn't actually go thru the strut tower, but is sort of welded to the engine bay side of the strut tower. What you have to do is drill this bolt out, put a new one in it's place and then add a backing plate.Originally posted by Rave669
does it use a backing plate on the mount? if not, that may prevent it from tearing the strut tower.
