I've got problems with my tranny. If your over like 7000 rpms in 1st, it will grind when you shift in to 2nd. if you shift between 5500 and 7000, it don't grind but yet its not smooth. under 5500 it seems to shift normal. any ideas what could be causing this.
syncronizer are worn out and the teeth on the syncro wont grab right going at a high Rpm cause the gears are all moving to fast for the gear to catch the syncro. my suggestion get another sycro gear set
Damn Lou. ATC is paying off... :chuckles:
and yea, 2nd gear synchro is shot. Warranty will replace it.
