1 - 2 of 2 Posts
Ok it seems that when Im cruising on the freeway in 6th gear and then I want to downshift to race someone then I push in the clutch as much as possible and put it into 4th gear and it grinds everytime. My 2002 GTS doesnt do this but my 2000 GTS does. Ive tested it on slower roads as well. If I do any downshifting to 4th gear while moving, it grinds. Any help would be great since Im taking out my burnt up clutch this weekend so ill have more access to the tranny if thats the problem. Thanks
Zettai Unmei Mokushiroku
Sounds like the 4th gear synchro is toast. Try rev matching or double clutching when downshifting and see if that solves the problem. If so, it's definitely your synchro.
1 - 2 of 2 Posts
