1 - 11 of 11 Posts
For those who missed out on the TRD Center Tach gauge face for GTS Auto...
Here is a simple way to convert the Manual to M-Mode...
This isn't a perfect solution, but better then I invest another thousands of dollar to put them in production.....
From close up you can see the little uneven cutting between the two piece, but if you are sitting on the chair, you won't noticea it..
Discussion Starter · #9 ·
LightningRod said:
Nice solution Sean, but it will be a problem for the 2003+ GT-S auto drivers due to the change in font ...
It doesn't matter... it works for both 00-02 and 03+
Discussion Starter · #11 ·
LightningRod said:
I meant that the fonts will be different.
Yea... it will be different... but if you really need to have M-Mode, this is only easy alternative....
1 - 11 of 11 Posts
