My68Spit said:
i don't quite understand how those are supposed to work. What is the difference?
If you mean the Komosport bushings, they are great!
The stock shifter is mounted using rubber bushings which give a lot of play in the shifter. Toyota most likely does this to give the shifter a more luxourous feel, etc.
Replacing the stock rubber bushings/mounts with the Komosport solid metal bushings eliminates the play and sloppy feel in the shifter.
The end result is you feel each gear solidly lock in place.
The throw is also a bit shorter becaust of the play that is eliminated.
I installed the Komosport bushings about a year ago and have absolutely no regrets. It`s very worth while mod particularly when keeping the stock shifter!
