OK so now that my stupid car is running again I got to Dyno the DC Sports header.
stupid scanner is being retarded so heres the text version.
**NOTE: This is done on a MUSTANG DYNO not a dyno jet so ignore the numbers and look at the gains. (typical 6% loss due to the 2782lbs load the cars were put under.**
Stock ECU/I/E
170.8 whp @ 8000 rpms
119.1 wtq @ 7000 rpms
Stock ECU/I/E/DC Sports Header
170.5 whp @ 7750 rpms
121.4 wtq @ 7000 rpms
Result - DC made basically same hp only sooner and made 2.3 wtq more.
Now For the Trial Header vs DC Sports Header comparison
00silvergts6spd/ DC Sports
N/A2zz/Trial Header
171.4 whp @ 8250 rpm
119.0 wtq @ 7000 rpm
**The first trial dyno was pretty bad so we used run # 2. DC only got 1 run so we didnt have much choices lol**
From 5300 rpms - 8000 rpms DC > Trial
at 6725 rpms DC > trial by about 15 hp and 15 tq
from 2000 - 5300 the graphs were identical. but trial stops going up and dc doesnt. then trial spikes a lil higher at the end of the run.
My conclusion TPR better get some good gains or we're screwed. Also FYI DC header did better with the power fc. not gonna talk about those numbers though cause we were tuning the trial but not the dc. (was not my tuning day) I just squeezed in 3 runs after we finished his car.
Stock ECU/I/E
N/A2zz/Trial Header
