1 - 20 of 86 Posts
keep spoolin..
Since I moved into the new house and bought a g35, considering parting out the celica and putting towards the house. Parts for sale would be:
*New sleeved block- has wiseco low-comp pistons, crower rods, mwr bearings, stock cams, mwr valves/springs, 750cc r/c injectors, smaay fuel rail, cf spark plug cover, circuitworx oil gears. $4000, or $2800 with your stock engine. would come with stock exhaust manifold and injectors as well, as i was going to break in stock.
*hotchkis competition sways (front and rear) $250
*bc inverted ram coilovers (8k miles) 10k front/12k rear spring rates.$875 ($600 w/ trade stock struts/springs)
*automotive progression oil catch can $70
*NX intercooler sprayer kit $200
*dd performance solid steer rack bushings $45
*rear hubs with solid bushings $150(w/ trade your hubs)
*rear suspension w/ full poly bushings $150(w/ trade your stock stuff)
*apexi powerFc $600 (no datalogit or commander)
*RMM front strut bar $150 (no sticker, also has little burn marks from battery cable)
*smaay big boy kit $1725 (manifold, dp, turbonetics t61, turbonetics evo wg) turbo has minimal play, can be rebuilt for $375.
*smaay fuel return system $250
*walbro 255lph fuel pump $80
*smaay e153 conversion. $1500 (needs 93' mr2 turbo throwout bearing and spring to hold in place, also clutch fork, then needs trans mounts built hence the low price. Trans has trd lsd, also brand new southbend clutch and pressure plate.) would trade for stock c60 and $500.
*c-one performance bars $125
*cf bb lip $125
*brand new mwr water pump/alt pulleys and belt. $150
keep spoolin..
You had an amazing turbo'd cell, sad to see it go. But GLWS!
Thank You!!! right now it is just interest though, and if i have enough i will part out.
keep spoolin..
Reading this kinda breaks my heart not gunna lie purpleharo.
yeah i cant really decide if i want to or not, hence why just gauging interest. If no interest really in the engine or trans, i will probably keep it. It just sitting in the garage and the house at this moment is more important.
keep spoolin..
keep spoolin..
Discussion Starter · #10 ·
keep spoolin..
ill be over there again for thanksgiving :p
keep spoolin..
keep spoolin..
Discussion Starter · #20 ·
I'll be interested in suspension related stuff as you know.
you should come up and swap your rear suspension with mine, the solid hubs and rear poly bushings. You can do payments since your close and i know where you live :p
1 - 20 of 86 Posts
