1 - 4 of 4 Posts
i live in england has you guys know it always rains here,
so im going to install a sri. is this one ok? i know the filters no good,
http://cgi.ebay.co.uk/00-05-TOYOTA-C...ayphotohosting
this is the first time i have seen one of these for sale in the uk this cheap.
i have only see them on usa ebay and post is a lot.
Has anyone ever fitted a air intake to the front of there celica straight to the air filter, that would stop people with sri getting hot air, WOULD IT WORK?
next question i have a custom sri on the car at the moment, sounds nice but one problems pulling off in first quick its fine up the rev counter (not hitting the red line tho), changing into second there seems to be a drop in the performances for a second and then it picks up again like normal.
Has anyone got any ideas, i have reset the ecu so its not that??
link on ebay not working. are you talking about a ram effect with the sri intake.?
and do you have a gts and falling out of lift in second?
here is the link again
http://cgi.ebay.co.uk/00-05-TOYOTA-...36680QQcmdZViewItemQQ_trksidZp1713.m153.l1262
here are the details :-
This air induction kit is designed to fit Toyota celica vvti 2000-2005.
Features:
* Our products are 100 % Brand New
* 1 pieces setup induction kit
* High quality Light weight Polish Chrome Aluminum material
* Cone gauge reusable & rewash able filter with 50% more filter surface area than stock!
* Polish chrome tube will reduces radiant heat by up to 80% over the stock tubing!
* Adds up to 5 to 10 additional horsepower and up to 16 foot pounds of torque ! ( result might be vary )
* No cutting or modifying on our product
* Smooth bent tubing reduces turbulence and increases Hp
* Improve throttle response throughout Low / Mid-range RPM
* Allow smoother, and faster air flow into your throttle body
* Better gas mileage and more intense sound under hood
* Easy installation
i have the gt 140bhp. i reset the ecu again (its still dropping performances when changing into second)
1 - 4 of 4 Posts
