Right now the car is doing about 234hp at 6000rpm, but then we having problems. Then they found oil on the cylinder 2 spark plug, so i am getting a quote on what it is going to take to replace the piston rings. The compression test on the cylinders were as follows:
1.220
2.150
3.180
4.190
Does that seem correct?
It sounds like it is hitting the rev limiter at about 6-7k rpm, but since the AEM FIC doesn't let you change the rev limit. It would be the spark plugs blowing out that would give the same results?
I know on MWR they have two different size rings. 70mm and 70.5mm, which should be correct for the 2zz?
Let me know what you think guys.
1.220
2.150
3.180
4.190
