because its possible the other half dont beat on their engine as much :gap:QTRMLR_1 said:is there any way to get my money back from UR on the crank pulley?
well I'll be calling them first thing Monday morning.
this is crazy, this is what they have in their catalog:
"You can always count on the quality of our pulleys and timing rings to keep your vehicle running for years."
The S in "Ultra S" stands for "Street" and I don't think they mean "Street Tires Only" at the track.
Why did only half of the people report problems? What was different?
A lot of it depends on driving habits and whatnot. The issue is undampened harmonics so it doesn't make much difference at the track seeing as how you only stay in any given rpm band for a very short time when drag racing - when on the street you tend to maintain certain RPMs for longer and accelerate slower, which gives the harmonics more time to act up and cause damage.QTRMLR_1 said:is there any way to get my money back from UR on the crank pulley?
That's misinformation right there... it wasn't half... and it was very few..Boosted2.0 said:Oh for the love of God - do a search this has been argues to death like 1000 times.
We did a survey a while back and about half the people that reported using the UR crank pulley experienced a shattered oil pump or bottom end failure afterwards. Undampened crank pullies have been proven to cause accelerated bearing wear and bearing damage or failure countless times. If you want to use one use it for track only and put your normal pulley back on for the street.
Ditto... 35k miles here with UO Pullies and 100k total on engine.hjkim483 said:I've been fine after 15000 miles. I've also done a couple NJ to IL driving for 850 mi each way.
I suggest you read a physics book on harmonics, you'll change your mind really quick.nyoneway said:That's misinformation right there... it wasn't half... and it was very few..
It's like doing a survey about blown engines and misshifts... anymore who bother responding are more likely the ones who were affected.
There are more people with the pullies than you think - in the hundreds. It's more than likely that out of the hundred of people, some are bound to have blown engines possibly due to other reasons and blame it on the pullies... just like how this guy blame his blown engine on a faulty Prodrive oilpump.
bull - go search out the post - it was over 40% - which is very close to halfnyoneway said:That's misinformation right there... it wasn't half... and it was very few..
You're worse than a magazine racer.Illusive said:I suggest you read a physics book on harmonics, you'll change your mind really quick.
And your an ignorant fool - whose worse?nyoneway said:You're worse than a magazine racer.
Searching:Boosted2.0 said:bull - go search out the post - it was over 40% - which is very close to half
but like I said - he just needs to search - its been argued to death.
I will say this though - if he blows his engine are YOU going to pay for it???
He experience engine failure. Can he prove it was the fault of the pullies?Boosted2.0 said:And your an ignorant fool - whose worse?
he experienced this first hand - yet you claim *he* doesn't know what hes talking about.
Thats not logic, thats just you having false hopes.nyoneway said:Searching:
http://newcelica.angrypacket.com/forums/poll.php?s=&action=showresults&pollid=829
Do you understand simple logic that:
1. Not all engine (oil pump, starvation) failures have aftermarket crank pullies.
2. Not all engines with aftermarket crank pullies experiences failure.
What kind of conclusion can you draw? None.
Want first hand experience? I have my UO pullies for more than 35k hard driven mile on a engine that's seen over 100k miles. So why haven't my engine fail yet?
Actually I did.Boosted2.0 said:
If you want more proof pull your oil pump and main bearings and inspect them - you will see all the proof you need
Really? Got pics to prove it?nyoneway said:Actually I did.
It was done 5k miles ago at the dealership when they did the TSB for broken lift bolts and tuneup/service.
thats weird.......they had to take appart your bottom end to get to the lift bolts that are in the head?Originally posted by nyoneway
Actually I did.
