1 - 3 of 3 Posts
Hi All,
My girlfriend has recently bought a W Reg Celica VVTI 140 with 100,000 miles on the clock. The car was supposed to have had a service before she bought it, but she has only had it about a month and it ran out of oil the other day. I know with Integra's they use a lot of oil, is this the norm for Celica's as well?
Thanks
Zettai Unmei Mokushiroku
Earlier 1ZZ Celicas did have oil consumption problems. It can be pretty bad sometimes. Only solution is to replace the engine, unfortunately.
If she is loosing coolant, check for leaks, check to make sure it's mixed correctly, and if you find no faults, maybe do a compression check to see if the head gasket is blown.
1 - 3 of 3 Posts
