1 - 4 of 4 Posts
is the TB vacuum port suppose to be plugged up when you turbocharge??? i've seen the SF kit...C2 kit and all that...its always plugged...is it ok not to plug itand just leave the lines going to the valve cover where it is
no thats very bad. that will pressurize your system and blow out seals...that port must be plugged...the end on the valve cover can be routed to an intake or a catch can
1 - 4 of 4 Posts
