I have a problem doing the vinyl dye
I sanded it down with 600 grit, cleaned it off with dawn, then heated it with a hair dryer. Then with the DupliColor flat black I tried painting it and after a little bit of drying the color would fade almost to that of the color of the original plastic. What am I doing wrong ?
O.G. Original Gluesniffer
Did you shake the can well? Are you painting outside where the temp may be too cold for the paint to atomize properly? Have you tried a different can of paint to see if you got a defective can? Other than those troubleshooters, I don't have a clue. I didn't experience that problem.
I only had that problem on two panels and it was due to the temperature going down, and not enough dye on the particular part... aka not enough coats.
I did paint it outside but Im in FLORIDA so how could that happen! Ahhh I hate running into problems
Also because this is a dye is it different than paint. Like do I just put one coat one day and then when its completely dry to the second coat ?
The paint could possibly be having problems with the humidity, but I don't know the exact weather conditions where you are to be sure. All I know is it needs to be at least 60 Degrees F outside.
At any rate, you don't have to wait an entire day between coats, just make sure the coat you lay down is dry to the touch before you add another coat.
