1 - 1 of 1 Posts
Morning all.. I'm trying to trace the reason I'm getting the dreaded P1692. I've tested/cleaned etc the vvtl ocv/filters and followed the tech manual to the letter. I've swapped out the vvtl pressure sensor for a new one too. So basically, when the CEL is off, she hits lift brilliantly all the way up, but after, the code pops up and then when I hit lift, the limiter kicks in at about 7.5k. I think I've worked out that the lift isn't disengaging and the ocv solenoid isn't closing. Now to my question.... This is the pigtail for the ocv solenoid (yes it stalls if I put 12v through it disconnected, and everything in there is spotless). I've put one multimeter probe in each of the connectors on it and I'm getting continuity. I'm assuming that this means I've got a short in the two blue wires somewhere?
1 - 1 of 1 Posts
