I'm having a weird problem with the lights in the center console.
- When blinkers are on, the LCD display in the gauges go off and on. Blinking oposite to the blinkers.
- If i put the dimmer all the way up the console lights go off. Only when all the way up. Otherwise they do dim in/out correctly.
- While driving the radio/ac leds dim or go out.
I guess i have a short, but where should i start looking to troubleshoot?
thanks
Sounds like a bad ground to the combo meter.
combo meter? where is that located?
Your gauge cluster - speedo/tach/fuel/etc.... is referred to by Toyo as the Combination Meter.
thanks! i searched on that and did the grounding mod for the cig lighter and it seems fine now.
Hmmm, interesting... as I have come up with a repair for the center console light dimming problem...
By doing that... you no longer have dimming control of the center console & radio. Did it effect any other dimming functions?
